- English
- Floodlights
- Arlo Pro 3 Floodlight
- Arlo Pro 3 Floodlight intermittently not detecting...
Arlo Pro 3 Floodlight intermittently not detecting motion
I just bought this Arlo Pro 3 Floodlight Camera on Dec 3. Things are good when the camera works. However, I find after working for few days, the camera does not detect any motion. I have to do either reset the camera by removing the battery or restart from the apps. It already happened to me a couple of times. I wonder if there is a Software bug that prevents camera to detect motion or if I get a defective unit. I have the charging cable plugged in all the time on my setup. Thanks in advance for your inputs.
hangun,
Are there any issues with signal strength to the camera? When you experience an issue with motion detection, do you see any error messages in the app?
I have the EXACT same issues with two Arlo Pro 3 Floodlight cameras (with Arlo mag charger), and nothing I do seems to work. I've actually tried to contact tech support on this issue and another I had a while back (disappearing recordings), but I've never received a response. I have about a week left to return these two cameras, so I believe that's the next step. I've had a pair of Nest outdoor cameras for years with absolutely no issues, so probably going to get a couple of their new ones and just a standard motion sensor floodlight. Too much money spent for this amount of headache!
pcainc,
What does the signal strength icon show for the camera?
Full Strength.
pcainc,
If you continue to experience this behavior, please contact the Arlo Support Team to further investigate. You will find several options for contacting support in the provided link.
Exact same issue here, returning it. 3 different customers, 4 different cameras not working is a warning sign, Arlo! And by not working: January 14th I'm doing literally jumping jacks at different positions in front of it. Nada. A car drives by at 4 am this morning, on the extreme edge of the FOV, got that on film. Walk right up to it, and across it, in broad daylight, nada.
I don't pay extra for the Arlo brand name (and 5-8 second system lag on a FULL signal indicator) for this garbage.
pm1066,
Consider increasing the sensitivity within your modes and rules for the floodlight camera and then test again to see if you experience the same behavior.
How do I change the motion sensitivity on my Arlo camera?
