Arlo 3 Pro Floodlight - not connecting
  • 1 Reply
  • 677 Views
  • 1 In Conversation
Tarad
Hi,
I recently took my Arlo 3 off its mount to charge it. On placing it back it showed it was still on charge. I went out of the app and back in, turned off and on and still showed it was charging. I then decided it was a good idea to remove it and reinstall it. However I have not been able to reinstall it successfully. Keeps looking for it and no luck. I have tried with and without the SmartTub setup.
I have also reset the light, it’s fully charged.
Any suggestions????
Tarad
Fixed, left on charge while connecting and it’s all fine now. Thanks
  • 1 Reply
  • 678 Views
  • 1 In Conversation
