Arlo Pro 3 Floodlight how bright is the LED?
  • 1 Reply
  • 745 Views
tarngmyna
Anyone have an Arlo Pro 3 Floodlight? How strong is the light? My wife made a comment the other day that our main camera in the center of the garage looks very pixelated at night. It's set to highest video quality and the spotlight is turned on. I also have 2 normal outside house lights surrounding it.
I'm guessing those 3 lights combind are just not good enough. That Arlo is wired to power so not concerned about it running out of power if I switch to the Floodlight model.
3000 lumens when on AC power.  Much brighter than the spotlights on the other cameras, and is a floodlight, so lights up a much bigger area.
Though you could also try turning off the low light color in your existing camera, and just using the IR Nightvision.
  • 1 Reply
  • 746 Views
