I just bought and set up a 2 camera Arlo pro2 system
but I've found the siren is very quiet, I have tried all the recommendation
turn off - didn't work
restart unit - didn't work
test from pc - didn't work
settings say very loud but its not
the main reason I bought the pro2 was for the 2 way audio and the ability to remote activate the siren too scary people away
can you please help
Have you adjusted the volume in the MODE for the selected camera(s)... ??
( it is pretty loud at max )
What model base are you using ??
the setting for the siren say very loud
the base station is a vmb4500
this seems to be a common problem
Same issue here.
Are pro 2s quieter than pros for some reason?
Bought because other people claimed that it was so loud you have to leave the room but I can sit quite comfortably right next to it...
Have contacted support but not much they can do. The suggestion was to downgrade to the pro base station..
Have you found a solution?
I have been contacted by support asking for more details but that was about 2 weeks ago and they haven't come back to me since
The service I have received from arlo is very poor, Amazon service was great and they sent me out a replacement but the problem was the same which makes me feel it's a software problem
I'm not downgrading to a older model, all I want it the product and service I've paid for
If they do have a problem then surely they should replace them with the pro3 hub
![michaelkenward michaelkenward](https://community.netgear.com/legacyfs/online/avatars/f_98444_Monitorsquare85.gif)
The "deafening" Pro 2 hub is the vmb4000.
It seems that the "update" is quieter.
Just another user
What's the point in having a siren that's barely louder than the TV?
Is the siren itself different from the previous version or can this be fixed with an update?
@Kentdude wrote:
But that's not what I bought the vmb4500 is listed and sold as having 100db siren
My guess is that, in its inimitable style, Arlo has failed to update the marketing guff.
I can't even find the vmb4500 in the document library.
The data sheet for the Pro 2 still bills the older hub.
Just another user
Old hub.
Just another user
same here. Bough mine arlo pro 2 with vmb4500 and my phone alarm or microwave is louder than that piece of c.
Phoned tech support, after the short convo they've told me to return it to the store. So I did and got a replacement...
Surprise, surprise a replacement has the very same issue. It's very quiet.
we seem to be getting the same run around, i had the same conversation followed by a replacement from amazon and the same result 😞
i logged a support call on 16th December and nothing
i logged another call 6th January and nothing
i get the feeling they know what the problem is and they don't want to admit it, i think its down to the new design
the older hub had breather holes to allow the sound out but the new 4500 is sealed
arlo should be replacing these hubs with a different model that works how it should, has anyone had any dealings with the hub that comes with the arlo pro3
at the end of the day all i want is the product that ive paid for working how it should
it would also be nice if support actually support the customers because without the end user they would all be out of a job
finally we might be getting somewhere
I've just spent about one hour on the live chat, they finally admitted they have a fault which they know about and are working on a firmware update for
but sadly they don't know when they will have a fix, i did suggest sending out the pro3 hub but that fell on deaf ears
so watch this space but i wouldn't hold your breath
Finally have a siren that makes a loud noise but I've been downgraded
Arlo finally sent out a replacement hub but their way of sorting the problem is to send me a vmb4000 rather than fixing the problem with my vmb4500
What are yours thought ?
I’m not sure it’s a downgrade to be honest, it has the same support camera wise and has a nice power button at the rear and a louder siren.
some times manufacturers alter the design to cut down manufacturing costs, this might be the case here but I would say it’s not a down grade and I don’t like units with no power button.
I personally would be very happy with the 4000 which by the way I have and I’m very happy with the rather loud siren it produces
I'm with @NewfieDrool. If it adds useful features, where is the downgrade?
New firmware has added compatibility with newer cameras to the vmb4000. What's not to like?
Just another user
