arlo pro camera used to work but no longer working
  • 5 Replies
  • 1048 Views
dangtran09
i replaced new batteries but still not coming on.
5 REPLIES 5
Assuming you're using a Pro 2 (that's the section we're in) try connecting it with the AC power adapter to see if that works. However, you say you "replaced new batteries" which leads me to believe you're not using a Pro 2 but the original wireless camera which uses 4 RC123  batteries. If this is the case, remove the batteries and just lightly place them in their slots, being sure to observe proper polarity. Use the battery door to do the pushing down of the batteries. ANy luck?
dangtran09
thanks, jguerdat.
i did connect the power adapter and the blue light flashed quickly and off.  however, the camera still say 'charge battery.  this device level is too low.  connect a compatible charger to charge the battery.'
thanks for any other suggestions?  or does this mean it's 'dead'?
Did you use the Arlo charger for the Pro camera, or a different one?
dangtran09
arlo charger
You can try a different charger to see if that helps. This may also be useful:
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
  • 5 Replies
  • 1049 Views
