What is this orange dot warning, bottom right on the video view on App?
Hello everyone,
Does someone knows what does this orange dot with an exclamation mark mean ?
I've got it on my iPhone 7 but not on my iPad Pro... ??? Strange isn't it ?
When I click on the "Live" button, it dissapears and then come again with "stand-by"
Any idea ?
The orange warning icon just says that the Arlo Pro 2 you are using doesn't have AC power and thus CVR cannot work. Have you got a CVR subscription? Or perhaps some zones enabled?
The warning just popped up out of the blue and the firmware says it’s up to date.
Why is the warning there? Do I need to reset my base and cameras?
Other people have said to uninstall the app and reinstall the app and it'll go away
This worked for me too... but I still don’t know the real reason of this bluddy orange dot !
Never mind it’s away!
I was going to buy more cameras, but I think it’s getting returned.
There is a persistent alert icon at the bottom right hand side of my camera feed. I found no reference to this in the manual. What information is this icon representing?
I found the answer. Delete and reinstall the Arlo app. This problem goes away. What is going on at Arlo? I’ve spent too much money (4 cameras) to have to deal with this foolishness from Arlo.
Is anyone still experiencing this behavior? As mentioned above, this icon will display if you have CVR or Activity Zones enabled on your Pro 2 while the camera is not plugged in. The purpose of the icon is to indicate that these features will not work unless your camera is plugged in.
