Web application scheduler doesn’t work over night
As discussed here:
https://community.arlo.com/t5/Arlo-Pro-2/Scheduler-doesn-t-work-over-night/m-p/1722835
Scheduling over midnight does not work for web application either.
Hi swenets,
Just to make sure, you're seeing the problem where your cameras does not stay armed once it hits 12 am? Have you tried using the new Arlo app?
Don´t know. The GUI does not support this.
Don´t know. I am using an app with date Aug 31 2019 and web application, neither GUI allows time to span midnight (two different days).
Could you clarify what problems you're exactly having? Are you saying that your cameras does not arm after midnight?
NO, I will say EXACTLY the same one more time: "I am using an app with date Aug 31 2019 and web application, neither GUI allows time to span midnight (two different days)."
I have attached a screenshot which shows that the "Save" is disable when trying to:
"start" at 11pm
"stop" at 01am
As a contrast the opposit works... 01am - 11pm.
It seems no-one has tested this in the WEB-APPLICATION.
I have not succeeded in using the IOS APP to do this either.
There's a workaround in this thread: https://community.arlo.com/t5/Arlo/Arlo-Wire-Free-overnight-scheduling/td-p/1213720
