Time filtering bug prevents video uploading to library need to be fixed!
I have encountered some sort of time filtering issue for approx 4 months, this is a bug and need to be fixed. I didn’t report the issue is just thinking the update could help, but so far, several updates released from Arlo, but the problem still there. I saw some people have reported the same issue in Arlo community but it looks like the technical team have no action on it.
Problem: I get the notifications of new recordings but I can't access or see them in my library until 10am, after this time the video uploads to library back normal. I'm on Australian East Standard Time. It shows the recordings from the previous day in the current day. It looks like the server or something in ARLO end hold the video from uploading to server until the specific time arrives. Camera captures video, so I have the notifications. We have different apple devices, they have same issues.
This is a bug that needs to be logged with the Dev team to fix.
sounds like your app is showing "library"?
My app is showing "feed" but seems to be having similar issue, since it starts showing local recordings under FEED > local (in parallel with Devices > base > Storage settings).
I am feeling they have mixed up interpreting time as local time vs GMT time. As a result, the recording you are after won't be considered as "today's" until Australia 10am (which is GMT 0:00 during UK summer and Australian summer time)
I must add this is my speculation. Afterall, I won't bother to troubleshoot these non-showstopper (at least to me) on behalf of ARLO. And even if I bother to help troubleshoot, they just won't bother to look into it and fix it.
Alex
@Jeff-W are you still seeing this same behavior?
Thanks Brooke for your asking, I am not sure if ARLO technical team took action on this issue, it looks like fixed after a few days since I wrote this post. As I have been overseas for nearly 2 weeks, I just came back yesterday, but during this time it works good, I will double check it and reply you soon.
with regards,
JeffW
Hi Brooke,
The issue still exists while I logged in through my iPhone 7. The app is up to date, I reinstalled it. The video shows up exactly after it passes 10am AEST.
My other Apple devices such as iPhone 12 and newer ones doesn’t have this issue now, it looks like fixed, we can check the video recordings in libraries nearly real time, no time barriers. It looks like ARLO’s video uploading net/calculations verifies different OS and takes different actions. I still suggest ARLO technical team to look into it as there may still some other users running the camera in such an old devices unless those devices were stopped updating.
With kind regards,
Jeff
Thank you for providing that information, I will pass it on to the development team.
