VMB4000r3 base station and two Arlo Pro 2 cameras that are both plugged in with constant power.
As somebody mentioned, the noise disapeared when I started to talk via the microphone button in Android app, but it comes back again.
Hello!
My camera has worked fine in the time I've had it, but recently notice that I hear a crackling / static noise every time I view it. Any thoughts? Is it possible it's going bad? I tried resetting everything, but still get the same noise. Thanks in advance!
Tom
Any news as to where they're upto with the fix for the audio crackling??
Could you plz give the tech ppl a rattle and find out, cheers.
I have been experiencing the crackling noises for more than a month. Arlo base firmware version 1.15.0.1_3162 etc. Noise emanating from all three of my AC powered Arlo 2 cameras. Running Arlo app on iPhone 10r, running IOS 13.3 Any solution would be appreciated.
I have recently noticed the same static audio issue as well. All three of my Pro 2 cameras are experiencing the same audio anomaly. This is a recent issue as I've had these cameras running without issues for the past 6 months.
The video below is from an Arlo Pro 2 camera connected to constant mains power. Base Station VMB4000 with firmware 2.12.3-2 01/15/2020.
You will hear a buzzing sound and water running in the background which is from a water circulation pump. The audio static is constant until :51 then disappears until 1:01
Edit: I found that going into audio settings for the camera and disabling the speaker function has prevented the static/cracking.
I recently (Jan 2020) purchased and installed an Arlo Pro 2 system. Hardware version H6. Firmware 1.125.13.0_31717. When monitor, there is a considerable amount of static and crackling noise.
I wanted to add that I reduced the audio speaker volume from 100% to 50% and there was still static and crackling noise.
I have 7 Arlo pro 2 cameras and every one of them are plugged in. I have just started getting this noise on only 1 of my cameras in the past few days. I have checked to see if all of them have the latest updates and they do. This problem is only with 1 of the cameras though.
version VMB4000r3
Firmware 1.15.0.1_3162_d878851
Constant issues with these cameras, disconnect randomly, or just won't pick up motion unless I remotely turn off and on, only 3 weeks old beginning to regret the purchase...
Was almost about to raise a warranty request!
I spent the morning running a couple wires to a few more Arlo lights that I installed a month ago, and went to check out everything when I was done. I noticed I have 2 more cameras that are starting to make the static noises, they are not anywhere near as loud as the first one that started making the noise over a week ago, but the static is there. This static is now affecting 3 of my 7 Pro 2 cameras.
I can turn off the microphone on the affected cameras and the static stops, but I like the audio portion of these cameras so I can listen for sound when I get an alert and the motion moves away from the camera.
I did try disabling the speaker, it doesn't make the static stop, only disabling the microphone works for me.
The Arlo Development Team is still investigating these reports. I will be sure to provide any updates as soon as possible.
I didn't go through every post, but I didn't happen to see where anyone was having this issue with a VMB5000. I currently have only a couple of my 4k Ultra cameras setup and they are all fine, but I do have a Pro 2 and it started to exhibit the same scratching noise being described by everyone.
The other think I would like to note is that my pro 2 also stopped recording to the my hub. I have a microSD card with plenty of storage. The 4k's sense and record fine. The Pro 2 senses motion but no recording.
All seemed to happen at the same time with the static noise.
Pro 2 Firmware Ver: 1.125.13.0_31717
Hub VMB5000r4
Firmware Ver: 1.15.0.4_297_aa40f04
