  • 13 Replies
  • 5677 Views
  • 5 In Conversation
Retired_Member
Not applicable
Can someone explain to me why each afternoon I get alerts basically every 2 minutes from this camera that alerts to a person detected.  I want to be alerted when there is an actual person in view, but why does it think either the tree or post to the gazebo is a person?
Between this and the double notification still not being fixed, I still don't understand why I still pay $10 per month for these "features"
13 REPLIES 13
Retired_Member
Not applicable
Retired_Member
Not applicable
No idea why I can't see the photos I have uploaded.
Retired_Member
Not applicable
Trying as an attachment
ShayneS
HI @Retired_Member
You can try toggling off "people" under the Smart Notifications for that camera. You can also try to reboot the base station ore reboot the camera by removing/Re-inserting the battery. Which version of the Arlo app are you using?
Retired_Member
Not applicable
App version is 3.2 (2202)
I restarted the base station and the camera just now.
Will report back if it continues.
Retired_Member
Not applicable
No change.  Next alert was for a person at the back door.
ShayneS
Have you tried removing & re-adding the camera to your base station recently?
Retired_Member
Not applicable
Did that yesterday as well made no difference. It doesn’t happen all the time. Just once the shadows change in the afternoon. There is nothing in that screenshot that should be confused as a person.
ShayneS
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Dannybear
The reason for the photos not being displayed is that they have to be vetted first which can take a few days.
The ir detection can occur due to sunlight reflecting from glass or metal surfaces when the sun gets to the right angle, then cloud can cause sudden changes that add to it.
The person detection could be the sun umbrella with the banded colour that looks like a shirt.
dcfox1
@Dannybear  I was thinking the same thing especially if even a slight breeze causes a slight movement.
ShayneS
Additionally, you can try adjusting the sensitivity to a value of 1% and work your way up to see if you can achieve the desired result. You might also want to try various locations for the camera or setting a zone for the area that is triggering the alerts.
Exec57
Your camera is detecting the shadows of the trees moving. I have the same issue. N o fix in the works
  • 13 Replies
  • 5678 Views
  • 5 In Conversation
