Now my basestasjon has stop blinking green in middel. The green light is constantly on now. What has happen? Dosent basestasjon no longer "talk" to the server? Everything works fine i think.
@TomMac wrote:
BUT if it is working fine, I would just power the base down and back up...let it reboot...
If it is working fine, then I'd just leave it be.
The normal status is solid green, so everything should be fine.
Blinking green means the firmware is being updated.
More info is here: https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-base-station-mean
Above is correct if the power button....
If it is the internet LED, it is normal to flash now and then as data flows.
easy thing to do and see if that fixes the issue.
(Looking at my pro2 base now and it is blinking now and then)
