Hi, I have been using my Arlo Pro security camera for close to 10 months. However 2 days ago it lost connection to the ethernet.
I have done the following but the base station is still not connecting and cannot be detected by the app.
1. I have reset my routers IP address
2. I have changed another LAN cable
3. I have reset my base station as well well removed it from my app to restart the pairing process, but it is not working still
4. The base station continue to blink in red light despite my attempts above
Please kindly advise how can I repair my base station and my cameras..appreciate the kind effort.
@jjongkp wrote:
What is the number for arlo tech support?
It depends on your country of course. There's a list here: https://www.arlo.com/en-us/support/contact.aspx
Googling will often find third-party support (many of whom are scammers).
Thank you for all the detailed information. I have provided these reports to the engineering team & will provide an update as soon as possible.
Thanks, we await further update from Arlo team.
Any idea how long it will take to update us? Seems Starthub will not do anything at their end...
Thank you KTR for the update. Have been checking on this community update status daily to see if there is any solution. I have not got any response from Arlo either. A bit frustrating at the moment.
I have the same problem. Was using my Pro 3 for about 2months until May and then it stopped and no matter what i did:
- changed the whole system with the distributor here
- reset
- power cycle
- use laptop to connect
- uninstall and reinstall app
all did not work.
I am in touch with the tech support from the distributor here, Kaira tech. If i get an answer will update the forum. If anyone else gets an answer please share as well. I also tried connecting my laptop to the same ethernet port that my base station was on and i can surf the web so its probably not a starhub or router issue.
Most of us seem to be people who know how to troubleshoot so we've probably done all they can advice us to do.
Arlo tech support has opened a case based on this thread, so we should keep posting here to keep this alive.
My feel is the auto firmware update bricked our devices and there's nothing we can do but wait. Which sucks. But I'll update here as soon as I get any info on my end, hope everyone else will as well
If you look back in this thread, you’ll see we have tried every KB article and suggestion from Arlo Tech Support. Multiple times.
It’s been 10 days since my system first went down, and I have spent at a minimum 10 hours on the phone and chat with them, repeating myself multiple times and getting issued yet another ticket number -despite me asking them to reference the very first ticket I raised.
An Arlo moderator commented at one point during this thread that they have forwarded details to engineering team and will revert. I have been told the same thing by Arlo support.
As previously stated, will update as soon as anything changes -including future conversations (call or chat) with Arlo. Please do the same if you receive any updates.
Hving the same problem with my Arlo. Thankful for this thread else I would hv just dumped my Arlo product.
Received an email from Arlo Tech support saying they would call today, and received a call within the hour.
The tech support person was from the engineering team and went through some additional details to do with settings, make, and model of my router and modem. She asked me to update DNS settings and confirm a few other details.
Arlo base station still blinking amber, and she said she was going to share this information with the team as they are working on it, and they would get back to me. She was very helpful, had all the previous info I had shared with the support personnel in the chats and in my tickets.
Looks like they have noticed this isn’t an isolated issue, and are actively working on a fix.
That's for reaching out to the MD and the update!
So I doubt it's a ISP issue, and still most likely the firmware update.
Would appreciate some updates from Arlo.
Morning folks, thank you very much for the relentless effort and updates provided thus far. Very much appreciated. Let's hope that Arlo can solve this issue asap.
Of course you have more information than any of us, but I think there are still some ISP possibilities.
In particular, I am wondering if your ISP is using carrier grade NAT (CGNAT) on their WAN network. That could create issues with the base->cloud connection.
I did a little googling, and some hits suggested that StarHub is using CGNAT unless you have paid for the static IP option.
Hi StephenB, It might be true that there are some ISP possibilities. The issue is that I have been using the base station since August last year and it has gone through at least 2 updates without any issue through this same ISP. If your comment about CGNAT is correct, I think I should have this problem for months now.
There is also a possibility that maybe Starhub did some changes recently that could also cause the problems we are having but I have a Sonos player that is also using port 90 and 443 and having no issues with firmware update. My Philips Hue bridge, Google Nesthub, IoT Wifi Digital Door lock and Synology station acting as a server are all connected to the same router and modem and none of them have any issues with firmware updates or operational wise.
I hope someone could say for sure what is the problem and if they have verified that Starhub is causing all these problems, then at least there is something we could move start acting on.
Having said all that, I check with Starhub and I am not under CGN. I have verified and can see that my public IP and my assigned WAN IP is the same...
Add another frustrating Arlo pro2 users lost the online connection suddenly few days ago. Trying all sort of things but can't get it work. I even bought another identical base station but encounter the same problem. ISP is also STARHUB!
As part of earlier troubleshooting i removed the device, and was never able to re-add it.
On Monday I noticed the light on my base station had changed from flashing amber back to Blue, so I tried to re-add it back again. No luck. couldn't find it.
Restarted the device. Stayed on Flashing Amber again 😞 and still unable to readd the device.
I have a friend who also lives in Singapore and has Arlo Pro 2 on Starhub and they've had no issues.
I can see my Base Station as a connected and active device on my network.
