Receiving alert on Arlo Pro but no recording?
  • 6 Replies
  • 1470 Views
RB2542
Why all of a sudden do I get an alert on a specific camera but, no recording?
Is there a way to reset the camera or something?
It obviously picks up motion but, the recording side is not recording.
6 REPLIES 6
Make sure you don't have a filter set in the library. The funnel icon at the top should be emptry, not filled. If filled, click on it and reset and save.
Holly1234567890
Hello I need too have the same problem. Have you fixed this or resolved it?
Holly1234567890
No filter set and have restarted it
Dannybear
Is the issue of no recordings with a specific camera and if so can you live view and manually record to the library ok.
When you’re on the App, check that the recording mode is activated for armed and any custom mode rules you have.
Holly1234567890
Yes everything is active. Yes I have restarted both the camera and questioned and the Wi-Fi router. It seems like the audio is not triggering the recording, but the motion is. Any ideas?
WHat detection method do you want to use - audio or motion? If only one, be sure to disable the other in your modes and rules.
  • 6 Replies
  • 1471 Views
