Receiving Error Message When Trying To View Snapshots
  • 40 Replies
  • 16696 Views
  • 14 In Conversation
Dannybear
Just updated to latest iOS app and seemed to be a harmless transition for iPhone 5s using iOS 12.1. I can see that a number of issues have been addressed so the development team is making progress. One observation so far is that I get an error message when I try to view snapshots from the library, it tells me that I do not hevc support and says to use another device. Videos play fine.
Dannybear
Update:
Updated to iOS App v2.7.2 and issue has been resolved. iPhone 5s and iPad Air 2.
Thanks to all involved.
40 REPLIES 40
ShayneS
How old are the snapshots you are trying to view? Do you have a screenshot of this error message?
Dannybear
@ShayneS,
Any snapshots taken by the v2.7.0 App. Attached is a screenshot of the error on my iPhone 5s. Also get the same error popping up on my iPad Air 2. Using the latest iOS v12.1.2. Btw unable to upload the attached photo to this post.
ShayneS
Thank You for the info. Do you happen to be using a usb drive for storage?
Dannybear
@ShayneS,
I am using two 8GB USB sticks for backup. I note that that I get no error message using the web App. Btw, Is there a problem uploading photos when posting?
Dannybear
ShayneS
Thank you for the information. I am not aware of any uploading issues. Can you try & remove/reinstall the app if you have not already? Can you try and upload the photo again.
Dannybear
@ShayneS,
The photo is viewable on my profile page. Attaching it in the post is not working or beyond me. I will try reinstalling the App again.
Dannybear
@ShayneS,
Same pop up appears after I reinstalled the App and view a snapshot.
ShayneS
@Dannybear
I found your photo, Thank you for that. Are all your cameras giving you this error? Which camera is the error message for? Can you replicate this issue with any other devices?
Dannybear
@ShayneS,
Snapshots taken on all three of my pro 2 cameras. Same error message is displayed on two iPhone 5s phones and iPad Air 2 using latest iOS. Web browser shows no error. All cameras and base have latest firmware. Only started after updating to iOS App v2.7.0
moorekev
Same problem also. Acts like snapshots are videos. Videos play fine.
ShayneS
@moorekev
Have you tried to reboot your base station & test again? What device are you experiencing this issue with?
moorekev
Arlo Pro. Yup. Rebooted. Same result. Honestly it’s just an annoyance. Once you get rid of the pop up you can view the pic.
Dannybear
This issue still exists for me using App v2.7.1.
The annoyance for me is when you have a large number of snapshots in the library, the pop up appears that number of times before you can view it.
ZonitGa
ReaXion
Also happening in the app with an arlo baby and on an iPhone Xs..
woodd00
I unfortunately don't have an answer, but I have been having this same issue. I will go in from an alert or just to check on things and all videos will be gone. Most of the time I will log out and back in and they will be there after the app has a while to refresh. I'll be curious if there is a response with a resolution.
It seems to differ depending on whether you're using the app or a web browser. In either case logging out and back in should fix it but, for a browser, clearing the cache does help.
MrBillf
I also receive this message when viewing clips, though not all of them.
As I first start to view clips to review and delete them from the mobile app, everything is fine. After reviewing several clips I will start to get the message "This video not abl eto play because your device doesn't support HEVC format. Please play in on a different device". It will then play the video clip.
If I restart the app, the issue goes away for a short while, then will start again.
If I receive the message for a particular clip, I can close the app, view the same clip and will not get the message.
Does that app get into a bad state that causes this issue? It can get annoying when reviewing a large number of clips.
iPhone 6s
IOS 12.1.2 (happend with previous IOS as well)
Dannybear
@MrBillf,
I believe that you may have a snapshot in your library that when the App is referring it causes the error message.
I can recreate your issue if I have a snapshot from yesterday and start reviewing today’s videos and deleting them.
To implement a work around, suggest that you delete snapshots in the library, downloading those worth keeping first.
A suggestion of why this occurs is that the video encoder is not setting the correct context for a video still frame and the App decoder thinks it is a video clip.
Dannybear
Just to update the thread, support are onto this now so I’m hopeful of a fix in their next App release.
Thanks to ShayneS for his support with getting this actioned.
Raven11
This morning I noticed two videos captured in my library. Both showed as recorded at the same time and both showed as manual videos. One had the play arrow displayed in the center of the screen and one did not. If I selected the video without the play arrow it would not play, but instead a pop up message would display that stated my device does not support HEVC format. The second video, with the play arrow, would play normally when I touched the play arrow.
what is HEVC, and what is going on?
my iPad is updated to the latest 12.1.3
HEVC is a new form of codec that comppresses videos to a smaler size...High Efficiency Video Coding;
 it may be in there for the Ultra 4k vids
Raven11
Thanks,
I’ve never had an Arlo video not play on any of my IOS devices before, and have never had one show a pop up window that stated “unable to play as device does not support HEVC format”.
I’m also wondering why it appeared in my library as a “manual” video (12:19am), what triggered the recording...audio and motion were both armed?
And why it won’t play on any of my IOS devices (fully updated Iphone7, IPad 6th generation, and my IPad Pro)?
  • 40 Replies
  • 16696 Views
