Retired_Member
Not applicable
2023-07-08
09:53 AM
The USB port on this unit, what is the purpose ?
can it be used to apply the wifi with direct access without having a paid subscription?
You can attach a flash drive to get local storage for backup.
With the VMB4500, the USB storage needs to be ejected from the base and then connected to a PC to view the recordings. They aren't available in the app or in the browser.
