Pro 2 with VBM3500 Base Where's the SD slot?
  • 2 Replies
  • 4185 Views
CaptainSid
Hi,
 Purchased at Costco a couple of weeks ago and generally like the system. However, for the life of me I cannot find an SD slot or USB slot anywhere on the cams or base. The base is the VBM3500 model. How do I record locally with this setup?
Thank you
You can't.  The VMB3500 is an entry-level base that unfortunately doesn't include local storage.
If you need that feature, then you'll need to return the kit to CostCo and get their more expensive version that has the VMB4000 base.  Or alternatively purchase a separate base (about $70 at Amazon US at the moment).
Today local storage is only a backup, though of course in the future that might change.
ShayneS
Hi @CaptainSid
The VMB4000 Base Station is compatible with the SD cards. This base supports the local storage feature. You can find more information regarding this base station here - Base Station for Arlo, Arlo Pro, Arlo Pro 2
  • 2 Replies
  • 4186 Views
