  • 2 Replies
  • 823 Views
dsocohen
I have two cameras that I’ve installed 1.5 months ago. One gets significantly more usage than the other. That camera has had its battery discharged to 1% about a week ago; however, it continues to function. Given its rate of discharge, it should be dead by now but it continues to function. The other camera has discharged to around 50% after the same 1.5 months of run time. I was expecting a difference in discharge rate between the two cameras, but not this significant. I’m questioning the accuracy of the battery level on the camera that is showing 1% but still functioning normally. This will be its first charge/discharge cycle so I’m not sure if there are battery conditioning issues that might be occurring here.
I suspect it's a display issue. Reboot the base and reinsert the camera battery to see if the display changes.
As a PS... do not let the batteries got totally flat.
If you do there may be an issue with starting a recharge cycle
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
I usu change out my batteries at about 25-30%
  • 2 Replies
  • 824 Views
