Is it possible to get a spare ribbon cable for the 6 way ribbon cable?
Is it possible to get a spare ribbon cable for the 6 way ribbon cable that sits inside the battery compartment? Mine has been nicked at some point which means that I cant run it off the USB power adaptor. Works fine on batteries but now that winter is here it means changing them every couple of days....
You'd have to buy a used camera for parts or invoke your warranty if still within that period. Contact support using the link at the bottom here.
