2025 September : Had Arlo Pro 2 for years with no real issue, good quality sound and video, and suddenly out of the blue, the recorded sound on live or record is very loud for no reason on all 4 cameras, 3 plugged in and one on a solar panel - same problem.
An update has been done recently (can't remember when - just realised the change lately) and this issue appeared. Software and hardware updates are done. Connecting and disconnecting didn't solve that problem. Videos are unusable now as this sound (static + clicking + amplified surrounding sound - although super quiet isolated area) is unbearable.
Just to be more specific: nothing changed in the location/installation/surrounding of those cameras, meaning no possible interferences or else.
A solution to this?
Best answers
A fix for this is already in progress and will be released in an upcoming update. Thank you for your patience.
Thank you for your patience. I am following this closely and I have requested for an update from the team. I'll be sure to add more info as soon as I receive it.
Yes. My issue resolved. Sound now clear. I removed my base station from the app then reinstated. Firmware was updated. All good ftom me. Thankyou @ShayneS
@ShayneS I was able to resolve the audio issues with all of my Arlo Pro 2 Cameras by removing them and readding them to the Arlo app. However, the one and only single regular Arlo Pro camera that I own still has a very noticeable loud audio noise similar to the issues with the Arlo Pro 2's even after I removed and readded the camera back to the hub. Does the new firmware fix both Arlo Pro and Pro 2's or just the Pro 2? Could you check with the developers and see if this should resolve this issue or not?
My Arlo Pro is running the following firmware on the camera.
Firmware version - 1.092.1.0_9_120d8b7.
Last 4 of serial EDIT
@panman91 Thanks for the update. Let me follow up with the team and I'll get back to you.
My two PRO 2 cameras are fixed and are much better now with the software fix. However my three PRO cameras still have the loud background noise. Tried removing them and reinstalling them a few times with no change in the background noise. I'll give it a few more days to see if they get any better.
PRO Camera Firmware on all three cameras: 1.092.1.0_9_120d8b7
Thanks for your help!
I've been out of commission for a little while and haven't responded. But removing and adding my Pro2 cameras back completely solved the issue for me. Thanks all!!
Hi
Are you still experiencing this symptom with the Pro cameras?
Hi
Thanks for checking in.
More problems. More problems. More problems. Mine don't play when I go into Feed. Only the first one or two. Then it's intermittent.
Is anyone in control of this development team? Is anyone in control of whatever is released? (Spoiler alert: rhetorical questions.)
Yes exactly the same. First one or two then its intermittent. So annoying
It's not just annoying. It's constant with every release. It's unacceptable. This is a commercial product, not some kind of side projects for hobbyists.
@TropicalStorm @Edinburgh_lad1
Please keep the discussion related to the original symptom being reported. if you're experiencing a different symptom, please create a separate thread and tag me. Keeping each thread focused on a single symptom helps ensure accurate troubleshooting, keeps investigations aligned, and streamlines the path to resolution for everyone involved. Once you've created the new thread, tag me and I'll be happy to take a look. This aligns with the community guidelines.
Thank you
