So my only question is...... did anyone else get the "firmware update" message this morning (6/7/2019)??? i did, for my two PRO 2 cameras and then checked back the device info-- still the same firmware as before... so was this mabe a glitch? or now i am wondering, is my cameras supposed to be updated now? anyone know of anything being released in the last 24 hours? thanks
Same happened to me. I just went to the base, made sure it didn't have any unusual lights and power cycled it. I check the base station FW and it is on1.12.2.2_2754 now. I believe this is an answer to the time zone issue. Now they need to fix the solar panels draining the battery.
well mine showed update--- then performed, now they work fine still. but when checking the firmware- its the old firmware from months ago still.
wait, what is the differnce from VMB4000 AND VMB4500 . they say both for PRO 2 but what is the difference?
my firmware for the base station shows 1.12.2.2_2754--- is this new firmware???
i know the cameras are on the old firmware that has been for months now
arlo pro base- our app says we have to do a firmware update for the base and cameras otherwise we cannot do live view - but the firmware doesnt update- it will go back to the old firmware and says error 4403.
Read my post....Go reboot your base station.
when you say re-boot do you mean remotely reset or actually on the base station to hit the reset button?
No!! Not a reset. Go push the power button to turn the base off. Then turn it back on. If your model doesn't have power button then just pull the plug.
Just newer hardware in the 4500. Functionaly, no difference.
Good luck fellow Arlo survivers 🙂
I had to perform a hard reset to update the firmware to 1.14.0.2_2776
