Trying To Reach 14' With An 8' Cable
  • 1 Reply
  • 1171 Views
DarwinsFlinch
I have a front door cam that I want to put on a charging cable. The issue I have is that my outdoor plugs are covered with spring plates plus the fact of a black cable to the cam would be like an arrow. I can plug inside, go through the wall and route the cord discretely, but I need about 14' to do this and the current offering by Arlo falls short (without the proverbial cable stretcher Man Wink). I know there are considerations with power attenuation over the increased length but I'm wondering if anyone come up with a solution for a similar issue of their own?
JessicaP
Hey DarwinsFinch,
You might want to consider looking at the Arlo Solar Panel if this might fit your needs.
  • 1 Reply
  • 1172 Views
