One of my cameras battery went dead and I can not get it to sync with the base station again. I have read through many posts here and have tried everything short of resetting the system, i think... Any thoughts to share?
make sure it's a quick press of the base sync button ( not hold ) and then the camera...
you can do this without the app/web access
If it fails, pull battery , replace then wait a couple min and trya again (after base stops blinking led )
Also try and move the base as far as possible from your router in case of interference
l try those items momentarily. Does it matter if the camera doesn’t show up as a device on my app anymore?
Still can’t get it to sync. Any thoughts?
Hi @JP5133
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
