  • 4 Replies
  • 1367 Views
JP5133
One of my cameras battery went dead and I can not get it to sync with the base station again.  I have read through many posts here and have tried everything short of resetting the system, i think...  Any thoughts to share?
make sure it's a quick press of the base sync button ( not hold ) and then the camera...
you can do this without the app/web access
If it fails, pull battery , replace then wait a couple min and trya again (after base stops blinking led )
Also try and move the base as far as possible from your router in case of interference
JP5133
l try those items momentarily.  Does it matter if the camera doesn’t show up as a device on my app anymore?
JP5133
Still can’t get it to sync.  Any thoughts?
ShayneS
Hi @JP5133
  Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
  • 4 Replies
  • 1368 Views
