  • 10 Replies
  • 2116 Views
Cosmo21
I took an Arlo Pro 2 camera offline from an existing account because it stopped working. I could not reinstate it. The camera has new batteries but doesn't light up at all at any point during the "add a camera" process. At one point, I get the message: “Looking for your Arlo Camera. Searching for any available Arlo devices. This may take several minutes.” But that message never changes or goes away. I found nothing about this problem in the manual. How can I bring my camera back to life? Will I have to re-sync it with the base station?
10 REPLIES 10
Dannybear
Will the camera come back to life if you plug it in external power?
Cosmo21
I don't know how to do that, because this unit is powered by batteries and not AC.
Dannybear
Do you have a arlo supplied charger cable and adapter?
What is the camera model number, is it a VMC4030?
Cosmo21
My camera is a VMC 3030. I bought my cameras and base station from Sams Club & didn't get a charger cable, except the one that plugs into the wall and is used with AC-powered cameras. This unit is battery powered (takes 4 lithium batteries).
Dannybear
Not sure where the confusion occurred but the camera model details indicate that you have an early version arlo wire free camera not a arlo pro or pro2 model that you originally started.
Have you tried using the arlo web portal on browser pc connected to the local network to add the camera?
Cosmo21
When I visited this site: https://www.manua.ls/arlo/vmc3030/manual  ...  it indicated that the VMC3030 is the Arlo Pro 2. I wo... adding the camera via the Arlo website but that didn't work either. In troubleshooting this problem, what are the possible reasons that none of the lights on a camera would turn on?
Dannybear
The VMC3030 manual is below for reference.
https://www.arlo.com/en-us/images/documents/arlo_wirefree/arlo_wirefree_um.pdf
The camera add instruction article is below.
https://kb.arlo.com/987/How-to-set-up-the-Arlo-Wire-Free-Camera
The reason for no led activity are
  • one or more batteries are flat.
  • the battery contacts are dirty or corroded.
  • the camera is faulty.
That site is incorrect. The VMC4030p is the model number for the Pro 2.  The VMC3030 is the original Arlo WireFree camera.
@Dannybear posted the correct manual link.
Cosmo21
Success at last! It appears the problem was dead batteries, even though they were never-used Eveready batteries. So I bought new ones today, followed the steps you indicated & now the camera works perfectly. Thank you so much for your help!
The batteries may not have been dead. You could test them with a voltmeter - they should show ~3.2v. However, a common issue is that not all batteries are the same dimensions. A slightly larger one may get stuck down when pushed into the slot. Always lightly place them in their slots and let the battery door do the pushing.
  • 10 Replies
  • 2117 Views
