  • 8 Replies
  • 2389 Views
  • 6 In Conversation
jimmyz1952
VMB4500  suddenly it is not recording to library.
ThaVWMan69,
Check your active mode, does the third camera have rules that tell it to record on motion?
You might also consider removing and re-adding the problematic camera to see if that resolves the issue.
8 REPLIES 8
DannyBearAgain
Are the cameras that are not recording pro2 or a later model?
Will the cameras let you live stream and if so can you make a manual recording that goes to the cloud library?
vintagehound
I am having this same issue.  I can stream live, but no recordings going to library.  They just suddenly stopped after working fine for several years.
vintagehound,
What model cameras are you using? Do you have an active subscription?
ThaVWMan69
I am also in this boat.  I have 3 Pro 2 cameras that have been working without any problems for many years.  2 of the 3 cameras still have recordings in the app, but the 3rd does not.  I do not have an Arlo Secure subscription, but these cameras did not require one for recordings.
ThaVWMan69,
ThaVWMan69
Yes, I checked there, nothing has changed on any of that since I initially set it up, that camera seems to have just stopped recording to the cloud.
I will try to remove and add back.
ThaVWMan69
Removing and adding back seems to have done the trick.  Thanks!
ahalye
I have the same issue.
  • 8 Replies
  • 2390 Views
  • 6 In Conversation
