  • 5 Replies
  • 2074 Views
Albors122867
I lost night vision in 2 cameras … Any advice ???
5 REPLIES 5
Verify that night vision is enabled in the camera settings. Reinsert the camera batteries to reset them. Possibly reboot your base. Bring a camera into a dark room and cause motion so a recording is made - do you see the dull red LEDs for night vision? Is the recording ok?
Albors122867
Hello ! I already did that... I took out the battery and put it back, it was fixed and now it happened again
Albors122867
The dull red doesn’t see at night .. the camera is recording good
Albors122867
I have 4 cameras it happen first in one now I have 2 with the same problem
Try removing one from your account and then add it back in. If that doesn't help, you may need to temporarily subscribe to a plan to access support.
  • 5 Replies
  • 2075 Views
