I replaced my old router with netgear ac 1750 model c6300v2. Now I can’t get a consistent internet connection with the base station vmb 3500. I had no issues with my Arlo system prior to replacing router. Anyone have any advice? I’ve done all the troubleshooting suggested but frankly seems to have made the issue worse.
I am really disappointed and think of looking at competitor systems since looks like replacement is only option.
Someone has a method for changing routers,
https://community.arlo.com/t5/Arlo-Pro-2/Base-station-re-setup-after-router-change/m-p/1876295
That method is overkill though, normally all you need to do is attach the cable. As I mentioned in my reply to that post, I switched routers recently, and that was all I needed to do.
Circling back to the main problem - @Cocoarmy: are you saying the the cameras/base are online sometimes, and offline at other times? Or are they never online?
