I have a new Arlo Pro 2 system, currently with three cameras installed outdoors. I have setup "Activity Zones" on two of the 3. The zones did not work, picking up motion outside of the zone. Both cameras are connected to AC power. After reading a few tech posts, I performed the following on one camera: Removed device from base station Removed and re-installed battery in camera Added the device again to the bast station Set up the activity zone. This did not work. I also tried to set up a separate mode just for activity zones. This also did not work. Any assistance would be greatly appreciated. Thank you Christopher
Hi @ceiffert
It took a while butr isolated this issue. The cameras will record on motion with no zones or 1 or 2 zones, add a third zone and they will not record on motion. I reporting this to a Arlo rep. She said they wil address the issue.
Well that solves my issue. After the update I added a 3rd zone and the recording has been non-stop.
thanks
Hi @sacharles
That is a good first step. Please continue to keep the Customer Support agent updated on any findings so we can get the issue resolved.
