  • 5 Replies
  • 1307 Views
RuskCP
I have never paid for subscription and the motion videos always appeared in my library. I have moved the equipment to my property with good wifi but I get no alerts or videos in library. Nothing has changed, no CVR, it worked and I got videos when I installed it. Any help would be appreciated. I can view live, but no vids. Help!
RuskCP
Problem resolved! I think it was the sensitivity mode was set too low for were I ended up placing the cameras. Once I dialed it higher, presto. Thanks for the replies.
5 REPLIES 5
Are the cameras showing up in the web ui and the app?  If so, can you livestream from the cameras?
Also, can you confirm that you have Pro 2 cameras (and not the newer Essential, Pro 3, Pro 4, or Ultra models)?
About how long ago did you purchase/install the cameras?
RuskCP
Yes Pro 2, yes I can live stream and the devices are there in app and website.
Can you make a manual recording?  (and then see it in the library)?
What's your active mode?
RuskCP
  • 5 Replies
  • 1308 Views
