I need help to change the email on my account. My X set it all up and I want to be able to give the base and camera to my son, but the X is still receiving the videos. Is there a way to change these if I have the base and camera in my possession and he lives across the country now? Thanks for your help.
Do you still have access to the base station on the web?
If you can login you can try to remove the cameras and the hub from the account.
How do I remove a device from my Arlo account?
Just another user
Your ex needs to delete the system from his account if he's the one that set it up initially. That makes him the owner and he has to remove everything from Settings, My Devices in his account. If you own the system in your account, make sure that he isn't granted access in Settings, Grant Access.
An alternative if necessary is to purchase a new base and set the system up new.
@Sese2019 wrote:
I have removed the base from my Arlo account ...
And the cameras?
Even if you have to have to bin the hub, the cameras may move to the new hub.
That would also deal with this:
@Sese2019 wrote:
...he got all the videos recorded yesterday at my sons house.
Attach the cameras to your hub and see if that works. This will break any link to the X.
Just another user
I suppose that workin with support, using your divorce decree or any other legal documents, may be useful. No idea if it would really work or if it's worth the time and effort but maybe...
