Just trying to see how they are holding for you after using tape mount for a long time.
Specially in areas of extreme weather like Utah that can go from below zero to over 100F
Thanks!!!
shaolin95,
While some users have had success using 3M tape, given the conditions you're describing, it would be advised to use a security mount. Take a look here for some outdoor mounting options: Arlo Products and Accessories
