- 2
Do I have to re add all my devices when moving from legacy to new app?? Why didn’t they move over with my account?
Have added the new app. The Base Station is not found. The first display “Add a Device”. The second display is “No Device Found”
I suggest contacting support. https://www.arlo.com/en-us/support/contact.aspx
UPDATE: Got it to work. Our power went out numerous times Saturday night and magically the new app found my base station and cameras on Sunday. Not sure if the many power on/offs had anything to do with it or not. Maybe restart phone and make sure the older app isn't running on another device? Good luck everyone.
Same issue, new APP can't find the base station.
@mldemmons12 wrote:
My Arlo cameras did not transfer to the new app. Any suggestions on how to fix this?
First I'd check the web interface ( https://my.arlo.com ) in a PC, and see if your cameras and bases show up there.
If they are, perhaps uninstall the app, and reinstall it.
If that still doesn't show them, then I suggest contacting support. https://www.arlo.com/en-us/support/contact.aspx
@Christamat wrote:
My new app will not dowload my base or cameras. It did not automatically transfer everything over and I have spent way to much of my time on this!
Try uninstalling/reinstalling the app, and then reboot the phone/tablet.
@Christamat wrote:
I haven't had cameras for more than 2 days now
I suggest contacting support: https://www.arlo.com/en-us/support/contact.aspx
I just called support.
I was told that since I did a factory reset (as that was the ONLY thing that allowed it to be seen with new app) on my base station, it cancelled my previous subscription. I was also told to upgrade my subscription, again...I used a different credit card, so time will tell if I get double billed for having ONE too many cameras.
I can now see ALL SIX cameras and everything appears to be working.
I certainly hope this does not happen again the next time they decide to "upgrade" the app : (
JUST AS I SUSPECTED!!!
I have a pending $9.99 charge from my old subscription that was supposedly cancelled (according to Arlo support phone call yesterday) when I did a factory reset of my base station.
The amount of time, effort, frustration and now to be double charged all because they updated an app?!?!
Good luck to any/all who had the same issue as me, I'm not sure the base station factory reset was the way to go but it was the only way the new app recognized my system.
My SmartHub/Base is offline. I tried everything, deleting the app and reinstalling on iPhone SE, I logged on Web, I tried to reconnect Ethernet cable, power on/off, reset. It is dead since october 11/2019.
We've had our arlo pro for the past 2-3 years with no issues until recently when we changed to a new iphone and downloaded their latest arlo app and now stuck with the same issue. We called it in and they said they will replace our base station and hopefully this will solve our problem. But it seems like from reading all the treads, the main issue stems from their latest Arlo app release not being able to find the base and the cameras.
and they tried to double bill me, yet again!?!? I do not understand what is so difficult here, i used the same email address. No one is managing this, at all. Just sit back and collect the subscription revenue. If i didn't have SO much money tied up in the cameras this entire system would have already been junked and i would be looking for something new. good luck
I keep trying to avoid installing the new one but my Arlo Legacy had been playing up keep asking to re login so I ended up deleting my old one which I regret it at the end. Now I am having trouble re-installing it to the new app.
Check your account email address and re-login If they say incorrect password. Get a new password and change it thru their website.
- 2
