After my arlo pro 2 records than stops but my camer is still showing movement when there is none. Then where is it won’t record. This is with all 3. Only way to get rid of movement is to go live but it comes back again after recording. This has never happened before have had my cameras for 2 years.
try and power button reboot the base unit... off then on, give it about min or two to come fully online
Thanks for info so far so good.
