My camera is not recording, and I can’t find the history of videos on the app
The same problem. My system stopped totally detect motion and recordings. Only the live screens works. Is the last update the reason for non working?
Earlier my two camera system has worked perfectly.
Did you verify that the proper mode or schedule is selected? How about rebooting the base?
I tried with ”custom mode” (what I´ve used for about 3 months without any problems) and a normal mode ”Motion and audio detection on” =Armed mode.
I have restarted the base unit several times without any help. The situation has stayed the same all the time. Only live screen with both of the cameras.
I would reset the system and start fresh. Remove all devices in Settings, My Devices. Use the Add Device button (web) or + (app) to claim the base. Sync the cameras. Update firmware if prompted as you go.
What mode are you using? If you remove the camera and resync it, the camera is removed from any custom modes. Only the default Armed mode gets the camera automatically added back in. Have you tried that mode (Armed)?
I just use the Armed mode, nothing else. I re-booted the system and disabled the camera with the issue and re-attached but it's doing the same thing. Not recording motion.
I'll add this is my only Arlo Pro 2 camera, the others are Arlo Pro. But they have all worked fine until a couple days ago when this one (Pro 2) camera stopped recording off motion. Thanks,
Try creating a custom mode to see if that works. Read the FAQs here on how to create it for full details.
Otherwise, I would restart the base, remove he camera again from Settings, My Devices and resync, followed by editing the Armed mode to make sure motion detection is enabled and set properly. Make sure your firmware is all up to date.
I tried those things and the 1 camera still doesn't work for motion detect. I also turned on audio detect (which I usually don't use) and audio detect works fine. I still have 1 Arlo Pro 2 camera that stop working for motion detect. It's also shows the latest update too.
