Hi, all 5 of my 2 year old cameras suddenly won't charge. I've done everything-remove batteries, swapped them, rebooted everything, plugged & unplugged. Still, nothing. It seems the connection to the shell cameras isn't connecting the battery with the plug in. I think they've become faulty from plugging & plugging from each charge. Disappointing because they're not cheap. Any suggestions? I have no functioning cameras right now.
If the camera works without the battery on the cable alone, the connection is good.
make sure your using the original ac adapter and cable... if so then
Read this ;
https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
@Hiyvettehere wrote:
, but would prefer magnetic charging so the constant in & out plugging in to recharge doesn't wear out contact over time like my cell phone chargers do.
That sounds like a good idea, so maybe post it in the idea exchange.
One challenge is that wireless charging requires a fairly large flat coil, which would be hard to accommodate in the camera design.
