Calling this a "Security System" is an insult to actual security systems. This product is beyond useless.
Problems:
-Failing to connect to Arlo Pro 2 cameras multiple times.
-When watching through the camera the video and audio freezes randomly (app and on desktop)
-When watching through the camera the video and audio freezes when it captures motion (app and on desktop)
-When watching through the camera the video and audio there is 30 seconds to a minute of lag time (app and on desktop)
-When watching through the camera the video and audio literally stops even though on the app or desktop app says its playing.
-When watching through the camera the video and audio just disconnect completely or stop playing all together
-Batteries take hours to charge in the charger it comes with
-Low quality video and audio.
The system is unusable, and I'm thoroughly disappointed I spent over $1000 on it.
A side note, I have good internet, FiOS 500up/down and all my wireless devices don't have connectivity issues.
I solved my issue with the Arlo cameras. I threw them in the garbage and replaced them with a real security system. I'm much happier now. Though, still sad about the $1000 I threw into the trash.
Please contact the Support Team to further investigate these issues. You will find several options for contacting support in the provided link. Arlo Tech Support
Hi Corbin
I am in total agreement with you on this. I spent a ton of money for what seems to be a worthless pile of junk. The only thing good for me is the video quality but what good is it if the system doesn't record anything. I have 5 cams and only one of them records!
Shane,
I have a lot of the issues that Corbin has but particularly most of my 5 cams are not recording so what is the point to this system. And btw calling support (whick i have done several times)does little or nothing. You need to stand by your product and make good on the money a lot of us have spent. I know that wont happen though.
@Shane49ers1 wrote:
I call in the problem but they say it's my current internet speed that's causing this issue.
- How many cameras to you have?
- How fast is your internet upload speed?
I suggest testing the speed with speedtest, since you might not be getting your usual speeds at the moment (given the much higher use of remote meetings).
@ShayneS Calling tech support is a huge waste of time. I've done it, multiple people have done it. Read what people are saying about Arlo Tech Support anywhere.
@ENF Yes, this system is a huge waste. I just hope other people see this before they buy it and purchase something else.
I have so many more complaints about this system but it's a waste of time to list them.
I would have paid something for them before u threw them in garbage.
Corbin... can I ask what system you got to replace your garbage?
@ENF DM'd
DM'd?
@ENF Direct Messaged. Check your inbox.
