Now the camera does NOT detect any motion when the garage doors are opened or closed.
I have tried increasing motion sensitivity from 80% to 90% and that still does not help. This is just one example I am finding with the degradation of the Arlo System. Searching for community help only returns very old info (mostly 2+ years old info). Has anyone in recent weeks experienced the same issue described?
The App version I’m currently using is: 2.19.2 (993), however the issues started a couple of releases ago.
The app has no bearing since it just displays what's available. The camera and base firmware could be an issue, however. I would start by removing the camera and resyncing it. If that doesn't help, I'd suggest a system reset by removinmg all devices from Settings, My Devices and start fresh to clear out weirdnesses. Be sure to note settings, modes, rules, schedule to speed the rebuilding.
Yep, same issue - 2 of my 10 cameras affected. I REALLY don;t want to do a system reset, as the cameras are mounted all over my work unit, on ceilings and it will be a serious bawache.
Any soft solutions?
While a reset is definitely a PITA, you usually don't have to actually take down the cameras. Pre-position the ladder as needed and then briefly press the base sync button (don't hold it for 2 seconds). Go out to the camera and press that sync button. I've done this numerous times. A camera with a weak signal could be a problem but one with a good signal should sync right away.
Please, report this to your software developers. Something has changed on Arlo’s end and has made your system useless and frustrating for your customers.
Since this is a user forum, your best bet is to use the Contact Support link at the bottom here and log an official case.
