Batteries need recharging every three days. Never changed location. Tried removing and syncing.
I have 3 Arlo pro 2 cameras, suddenly the batteries are not lasting more than 72 hours of all of them, they are in the same location as they were for the past 2 years, no changes to the surrounding or interference.
I have removed the cameras and synced them again with the base but no luck, I have swapped the batteries on all cameras with each other, still the same problem, am I supposed to change the batteries after 2 years?!
Thank you for your help in advance
While a PITA, it may be worth a system reset to see if that helps. Note all settings, modes, rules and schedule to speed the rebuild before you remove all devices in Settings, My Devices so you can start fresh. No guarantees.
BTW, you're not turning off the base, are you?
Thanks, off course l’m not turning off the base, I have restarted the base yesterday, since, it seems ok, also for some strange reason, it deleted all the rules so I have set them up again, so far the batteries looks alright to me after the restart
