There are no recordings in my lib rary anymore. Camera profiles show there are recordings but the library has no recordings.
You are missing recordings for which cameras?
Do you have CVR enabled?
***Previous Post***
"I have a few questions for you
-Are the recordings missing on the web portal & mobile app?
-What version of the Arlo mobile app are you experiencing the issue with?
-Which Phone/OS are you using?
-Which Cameras are you experiencing the missing recordings from?
-Do you have CVR enabled for any of the cameras missing recordings?"
RobKelly, I've been having the same problems, not recording. What's the point of the cameras then?! I guess Arlo thinks we'll be happy watching live video of our stuff being broken into and stolen? No thanks. I'm done. Goodbye, Arlo. It's time to switch. I'll be going with Wyze.
1. I deleted all 3 cameras.
2. I deleted the base station
3. I unsubscribed from the premium service.
4. I add the base station from the app
5. I added each camera in turn from the app. I did not recycle the power, just pressed the sync button etc
6. I removed all custom modes and set the current mode to ‘armed’
7. I removed all schedules
8. I did not set up any zones.
All is working fine, even the camera due to be replaced tomorrow.
I’m going to run it in the most basic sense until I’m convinced that Zones, subscriptions and notifications are working again. Good luck!!
Hi ShayneS,
I have a ticket opened with support since this morning. The recordings are missing on the web portal and both Android and iOS apps. I did confirm if you go to live view and manually record that shows up in the library, but none of the normal recordings are appearing in the library. For me, this is across 5 arlo pro 2 cameras, 2 of them are wired to power and 3 of them are on battery (100%, 51%, and 10%)
I haven't had a recording appear since around 10:30 PM PST, I've restarted the base station, did not do a full power cycle by unplugging the unit. Nor have I had a chance to remove a camera and re-sync it, but I will try those tonight when I get home. I am also curious if local recording is capturing all the events, which would point to an issue strictly on the cloud side.
I am running Android 9 on the latest app version, my home base and cameras are all updated on the latest firmware, no CVR on any cameras.
Smart notifications not appearing on android phone also no clips showing in library since 10:00 am this morning, I have removed and reinstalled apk on cell phone also rebooted base and check all settings, no change. There apparently was update today and it has created this problem . I have premier plan and I think Arlo should give discount for the inconvenience since I am paying for a premium service.
I have same problem. Arlo Support should really check their cloud servers before they start messing with customer's cameras. Re-Synchronizing does nothing other than wasting our time troubleshooting when it's their cloud servers not working.
It's a central problem. There are other forums on this topic going on. And yet Arlo support will waste our time messing with our cameras by having us re-synchronize the cameras instead of first checking their cloud servers. I wonder why their stock price has been taking a dive.
Same problem here. About to chat with support but wont be touching a thing until they look at there end.
- both App & Web
- iPad Pro 11” / iOS newest system / newest version of App and maCOS Catalina / Safari
- Arlo Pro & Pro 2 ( 1 pro2 works, 2 pro work, the others (1pro2 and 3 pro don’t work)
- Smart Premier Plan (no CVR)
why is there a new problem every month? How are you testing software updates?
I only have 1 camera. I dont know what CVR is. However whatever settings I had yesterday I had today. It was working fine then but not now.
This morning all my battery powered cameras developed the same issue. They are all connected to the base station, they all function correctly except they fail to register any recordings. My Arlo Q cameras are unaffected. I've restarted each camera with no success. I've also restarted the base station several times but still the cameras are not registering any recordings.
Has anyone else experienced the same issue. Is it due to the latest update?
Cheers,
Dave
So my Arlo has stopped sending notifications through. Even though it is set up to be and i have checked my phone settings and they are on. It seems to be one specific camera that does it then all of them drop out.
I cant turn automatic overwrite on as it doesn't let me swipe across on the app. So i deleted all footage to make room and it made two cameras start recording but still not any notifications and one camera isnt recording anything again.
I have tried resetting the base station and re syncing cameras.
Helllllllllp
I have tried getting onto live chat for two days, doesnt work, sent an email and have been on hold on the phone over half an hour!
Having same problems on Arlo Pro and Pro 2.
Tech said they have problems with their cloud server.
This is the worst security camera system, EVER!
						Arlo Mobile App629
						Arlo Pro 211
						Arlo Smart180
						Before You Buy995
						Features441
						Firmware Release Notes57
						Google Assistant1
						IFTTT (If This Then That)24
						Installation1,148
						Online and Mobile Apps865
						Service and Storage317
						SmartThings37
						Troubleshooting6,322
