Motion Detection not working on my Arlo Pro 2
Hi @JeffNolan18
i have a few questions for you. Did this issue occur recently? What devices (Phone/Tablet) are you experiencing this issue with? Have you made sure the Base Station, Cameras & Arlo Mobile App are up to date on the latest firmware? I have provided the link here - Firmware Release Notes
First off I need to clarify. I have a Arlo Pro, not Pro 2. Sorry.
This issue has happened since the first time I set it up right out of the box.
I’m experiencing this using the Arlo app on my IPhone 6. I unfortunately don’t have another device to test it on.
I’m pretty sure everything is up to date because the day I set it up there was a firmware update.
I can’t even perform the motion detection testing where the yellow light on the camera is supposed to come on. I try and no yellow light.
Thanks,
Jeff
I have the same issue. The yellow light will only turn on when the camera is powered by the battery only. You will not see the motion yellow light when the camera is plugged in. The motion sensor will work when the system is armed, so I tested it with the sytem in armed mode.
Do you have a rule set to send push notifications when motion is detected? Are you receiving videos in your library?
Have you tried contacting customer support regarding this issue? I have attached the link here for you -Arlo Tech Support
I’ve only ever received videos in my library when sound has been detected. Never for motion. Yesterday my cat was walking around in the main zone, eating, jumping on the couch and that didn’t even detect motion.
Motion alerts and e-mail but all there show motion alert in black. All three were sending notifications and alerts when they were first setup inside pointing out. All have the most same recent firmware. Any ideas? It’s a waste of hundreds of dolllars if it doesn’t alert me.
Do you have the activity zones setup? If so, can you remove the zones & see if your camera detects motion.
Hi @KS1949
Can you provide a little more detail regarding the "black" motion alerts? Are the videos in the library appearing black?
Hi @JeffNolan18
If you are adding/removing activity zones from the Arlo Mobile App, you can swipe left on the desired zoe to delete it.
Hi @KS1949
If the Logos are black that means the rule is active. If it is grey, the mode is disarmed. Example - (A Black Circle With 3 Lines = Motion Detection Is Active).
The activity zone should be in the video section.
Refer attached for iOS App.
From the devices page, I just tap on the settings icon for the wanted camera and it takes me to the camera settings.
If I tap on the settings at the bottom right of the App then I tap on “my devices” I then have to tap on the wanted camera to get to it’s settings page.
I advise from my experience that you do not use the basic activity zones as they will corrupt the schedules, modes, rules stored in the base station and will require you to re-enter them again each time the activity zone detection is activated.
In my app I don’t have Activity Zones below Voice Settings like you are showing me in your link. All I have showing is Video Settings and below that Audio Settings.
Hi @JeffNolan18
