Pro 2 (1 month old) went from 90% battery to 1% in a few days using Arlo Solar Panel
Bought a Pro 2 to replace a Pro camera last month and attached the Arlo Solar Panel to keep it charged. In a few days, the camera went from 90% to 1% with only 10 triggered videos. This is unacceptable. Either the battery is defective, the camera is defective, or the solar panel is defective.....either way I need a fix as both the camera and solar charger have just pushed past the Amazon return window.
FOr starters, reboot the base and reinsert the battery into the camera to see if there's a difference. Otherwise, you have a 1 year warranty so open a case with support:
That doesn't look right, but remember it isn't just the number of camera triggers that matters.
If you have a camera that is struggling to maintain a wifi connection with the base station, that will eat juice.
Just another user
