Modes labeling base 2 base stations wrong - Android 2.12.1
When I downloaded the new Arlo Android Mobile App version 2.12.1 last night I found that the 2 bases I have on this app will flip flop when opening modes. As said I have 2 bases labeled base 1 and base 2 is labeled 2nd base sometimes when opening modes the 2nd base will be on top and base 1 will be below it then if I close the app and go back base 1will be on top and 2nd base will be below it like it always was. Strange.
Iam glad to see they fixed the disappearing base mode status as the new update is working great except for this.
Forgot to say I did delete the app and re-installed still the same issue.
It may be a timing issue. How fast did you go into the Mode tab after opening the app? As a test, try opening the app, pause, maybe check the library, and then go into the mode tab. Does that make a difference?
I thought that too jguerdat that it being a timing issue but I have paused before going to it sometimes I have been in modes and it was the correct line-up then saw it flip flop.
