I have been having trouble with my live view not working. I have contacted arlo and still no joy. It will finally connect, with a 13 second delay and then after 20 seconds or so it will disconnect itself. I have swapped cameras, reset the main box thing.
The cameras are plugged in and record movement and that video fine. BUt anytime i try to view whats going on live it will not work. and the same with audio... huge delay!
Any ideas? I work from home some days and want to keep tabs on my store and the live view would be nice. This happens on my phone and the laptop using the website.
I occasionally have the same issue with one of my cameras that has a tenuous connection to the base unit. If you're connection isn't strong, can you try to move the camera closer or with better LOS to the base and see if it improves?
What are your Upload/Download speeds? have you changed your internet service or router/modem?
I think it is 300 down 30 up
Is this with all the cameras? Is it isolated to the Arlo App or does the delay occur on the Web portal as well?
Yes this is with all cameras and on the app as well as the web version.
