My phone is an Android Galaxy S8 (SM-G950U) Android Version 8.0.
Just got the system last night and setup a few of the cameras. I can watch live view from any PC but when I run the phone app, all of the features work accept Live View. I get a wait spinner that says "Connecting..." and it just sits there forever. Any workarounds for this? I can view the recorded videos from the phone and make changes to the system just can't get Live view to work.
Thanks, Jeff
I am also having live view problems on galaxy note 8. Just uninstalled and reinstalled the app. No fix. My internet and wifi connection is fine. Ive had the kit 6 months and only recently stopped live viewing
Android Apps are having Similar FREQUENT NO VIDEO (Black Screen) or VERY LONG Connecting Times or Device is NOT STREAMING in Both the Last 2 Firmware Updates! Website Interface is OK which proves the Problem is the APP! Level 2 TECH SUPPORT NOT Relaying this info to USA! Ditto on the PoOR Software Design with NO TESTING Before Release!!!
Ok so I posted a second message into the topic and it got deleted. I posted several criticisms of the system from my experience so far. How odd, maybe because it was off topic and not because of the criticisms. At any rate seems like I can get the phone app to show live information about 30% of the time now. Almost feels like the Phone app is ignoring my wifi connection and using my cell connection. I seem to get a better chance of connecting if my cell reception is perfect regardless of my wifi connection.
jdamp,
How many cameras are giving you the live feed issue you are experiencing? It sounds like there may be some interference issues happening within the area. Have you tried to reboot your base station or remove & re-sync the camera? Can you bring the camera closer to the base station and test again?
I checked the desktop live view last week and it was fine. I will try a more recent time after work. So far i also believe its the app is the problem
All of the cameras give me the same issue from the Andriod app. Doesn't matter signal strength etc. Yes I have resarted the base station and cameras. From PC they play fine. Now viewing a recorded video from Edge doesn't work, I have to download them.
@Jaz1140 Yes viewing recorded videos from the phone works as expected. Just the Live view is broken.
jdamp,
Is this loading issue happening through wifi, cellular data or both?
Wifi & Cellular Data - FREQUENT NO VIDEO (Black Screen) or VERY LONG Connecting Times or Device is NOT STREAMING in Both the Last 2 Firmware Updates! Website Interface is OK which proves the Problem is the APP!
Yes just tested and it is the same on wifi and Cell (regardless of strength). I noticed when I first got the system live view worked well from my phone then I did the firmware updates and it was at that point it didn't work very well. Seems like some incompatability between the two. Also I assume PC and phone use the same web service to comunicate with the base station i.e. phone/browser<->Arlo web service<->My base station. If Iwere you I would get a service engineer to validate that the phone is sending the same headers and data up. Really you should have service logs of these failed comunications but hey what do I know. I guess I could install wireshark and put the base station on a hub but that sounds like something someone at Arlo should do.
I ended up installing Puffin browser on my phone. Works 100% of the time no connection issues. Puffin does Adobe Flash cloud based rendering. Not sure if I trust proxying through them or not so would much rather have the phone app fixed.
I'm on a Galaxy S8 android 8. I wish the Arlo web site would stop using Flash. There is a very good reason that it is being deprecated. It blows my mind that a security related product would use tech that is laden with vulnerabilities.
Jaz1140,
What android version is your Note 8 running?
