Issues with new Arlo Secure App
The recent update to new Arlo Secure App is problematic.
FIRST we weren't notify of it. I discovered the change when it seemed there was a problem with it as my video feed was acting crazy. I installed the new system from my PC.. Its a LOT of changes... not as simple as before... Eventually I figured out how to navigate... HOWEVER ...
While my Battery Powered Cameras and feeds work fine with only the normal lag time, nor so with my wired doorbell... I get Black screens...sometimes with audio, sometimes not... sometimes a pixelated video
... so its NOT a wifi or internet issue as the battery powered camera feeds are ok.
Seems there is a new Arlo server that the new Secure App system has at the back end.
Can you please send screenshot of what you are seeing with the wired doorbell?
The issue seems to have resolved.
I agree the new app. is terrible. Support know as much as me. Hopeless app.
This App is not usable. I’ll bet it was written by AI. The entire upper management should be review by DOGE!
It’s not usable at all.
@Droopy_98 if you provide more information on what you are seeing, we would be more than happy to help you.
Unfortunately, the app cannot be installed. I have tried multiple times to upgrade it. I have chatted with technical support. I have worked with them over the phone. They are not capable of troubleshooting.
To what device are you trying to install the app?
What OS version is that device running?
