  • 4 Replies
  • 2289 Views
Moxilla
New to using an Arlo system, and the first time I needed to change a depleted battery for a charged one, I turned off the device in Device Settings and swapped the batteries. But when I tried to turn the device back on, it said battery needed changing. Tried another battery and it was okay. (Hope that battery isn't bad. Will test later on another camera.)
I checked the manual for this issue. My question is should I turn the camera off  in the device settings on the app before I swap out the battery?  If not, can someone tell me the correct procedure?
Thanks.
michaelkenward
Sensei Sensei
Sensei
I don't.
I simply remove the battery from one camera and move it to another one. This has never caused anything more than a temporary disconnection.
I do this because I have a couple of batteries on mains power and some on battery only. When the "battery only" cameras send me a power warning, I take a battery out of a mains camera and swap it with a batteried camera.
This has been my strategy for a year or so with Pro 2, Ultra and Pro 3 cameras. No sign of damage so far.
Just another user
michaelkenward
Sensei Sensei
Sensei
I don't.
Just another user
Agree... just swap the battery and the camera should auto-resync
Rob-A
I agree - I do not disable the cameras before changing the batteries and have had no issues.
Moxilla
Thanks everyone for your responses.  I think I may have pressed the sync button after installing a fresh battery the first time, which I now realize was not necessary, since the camera was already synced. That probably confused the camera.
Camera and both batteries are working fine.
Thanks!
  • 4 Replies
  • 2290 Views
