Using 3M Command Mounting Strip (16lb strength) to mount camera
  • 1 Reply
  • 3654 Views
Paulx
I used the 3M Command Mounting Strip to mount the camera. The 16 lb strength.You can mount any where without nailing into the wall.
JessicaP
Hi Paulx,
While this may work, we don't recommend using 3M Command Mounting Strips to mount cameras. We encourage using the mounts included with the Arlo cameras.
  • 1 Reply
  • 3654 Views
