I'm impatient to wait for the Arlo Pro 2 to come to Australia and intend to purchase it from USA. (Amazon website)
In the future, I plan to add other Arlo cameras (e.g. Arlo Q for inside house). If I have an Arlo Pro 2 base station is it compatible with Arlo products from Australia?
Apologise if this question has been repeated. Have been searching through forums but couldn't find a similar question. From looking into the forums, I'm aware the Arlo cams are charged from USB charger so I'm hoping they are universal and not dependent on locale, (geographic location) and only the base station needs a transformer. (Convert voltage from 210v to 110v)
All Arlo cameras are compatible with all Arlo base stations.
The USB adapter states on it 100-240v ac @ .3a input ( US prongs )
But is is just NOT a standard USB. It is a qualcom type dual voltage output , 5v for running, 9v for charging the battery pack
The base still takes 12vdc on a coaxial plug so a tranformer will be needed
AFAIK, the Pro 2 base station is the same as the Pro base station and should be 100-240V rated. All you should need is a travel adapter/plug pin adapter. Do you already have any Arlo cameras? I bought Arlo Pro locally, despite the $$$$, and then bought add on Arlo Pro 2 cameras from Amazon. It works well. I had originally bought an Arlo HD 4 camera kit locally and I'm glad I did because of warranty issues with that original kit.
Great idea. Havn't brought the cameras yet, going to go with this approach and buy the Arlo Pro base bundle and buy additional Arlo Pro 2 from USA.
Cheers!
