flat batteries arlo pro 2
  • 2 Replies
  • 2006 Views
aeiths4
why does my batteries go flat very quickly sometimes 24hrs. it’s when i bought it was fine lasting 6 weeks then the last 3 weeks they drain quickly. i have 2 batteries it’s all new only 4 months old. i have fast Wifi speed. can someone help.
st_shaw
Master Master
Are your cameras outside?  What's the outside temperature?  Lithium ion batteries lose capacity substantially as the temperature drops.
Your WiFi speed has no bearing since the Pro series use only a connection between the base and cameras. However, your WiFi may be causing a problem with interference on that connection. Try moving the base away from the router.
  • 2 Replies
  • 2007 Views
