Not wanting to detract from those struggling with the Arlo vs AT&T outage. (Hence the seperate post)
This presents an opportunity for those impacted to start checking if their USB backup recordings are working correctly as advertised.
Any takers?
My USB drive records everything fine but I put a USB in both ports and system only shows one
Thanks for checking, I was alluding to the issue that when the internet fails any recordings to the USB from powered cameras get truncated to 2 sec.
As far as your second USB not showing, suggest you have a read of the faq about backup USB format and size limitations.
